I was spooling off some 16/3 SJOOW cable that I needed for a project that I am working on when my hand felt like it was being jabbed with a needle. Upon closer inspection, there was a spot on the cable that had some very fine wires poking through the outer wall of the insulation, almost like it was the individual wire strands from the conductors inside the cable.
Kind of hard to see in the pictures.
I looked at the rest of the spool, and sure enough, there were several spots on the spool that had this same damage. This came from the manufaturer like this. I looked at the lengths of cable that I had already cut off and, sure enough, there were several spots that had this same damage. At this point, I rounded up all of the cable that I was using as well as the rest of the spool and am having our purchaser contact the supplier to see if we can get a new spool.
No, I did not even bother with opening up the cable to find out what the damage actually was. At this point, I do not trust any of the cable from this spool. Now I am going to backtrack to all of the places that I have used the cable at in the past month to see if there is any more damage.
Anyone else ever see any kind of damage like this on a spool of cable?
