nietzj
- St. Paul, Minnesota
- Electrician
I have kept my Journeymans license for years even though I have a Masters license. Is there any good reason to keep doing this?
Here, the contractor's license is granted only to a business entity, while the electrician's licenses are granted only to individuals. A contracting business must have the former and employ the latter.I have a contractor license, but if I wanted to go to work for someone in a journeyman position my contractor license is valid for that purpose.
So if you wanted to get a journeyman position job, do you need to apply for a journeyman license? If you do that do you either need to forfeit your contractor license or at least maintain two licenses should you ever want to do contracting again?Here, the contractor's license is granted only to a business entity, while the electrician's licenses are granted only to individuals. A contracting business must have the former and employ the latter.
One has nothing to do with the other. A master continues to qualify as a journeyman, because being a journeyman is a stepping stone to becoming a master, but you don't lose the journeyman qualification when becoming a master. My license still shows both.So if you wanted to get a journeyman position job, do you need to apply for a journeyman license? If you do that do you either need to forfeit your contractor license or at least maintain two licenses should you ever want to do contracting again?
Not quite the same, because a colonel can do anything a major can (RHIP), but remains responsible for his assignment (RHIO). A master electrician is not required to do electrical work, but is required to be so licensed if he wishes to lead jobs that a journeyman may not.Seems a little like a military man holding ranks of a Major and a Colonel at the same time, Uncle Sam is only going to pay him one rate, so the Major title serves little purpose even if his primary job is a job normally performed by a Major or even if he does some tasks that typically are only done by privates.
Bold face answered my question. You still have one license, it just shows both qualifications in some way.One has nothing to do with the other. A master continues to qualify as a journeyman, because being a journeyman is a stepping stone to becoming a master, but you don't lose the journeyman qualification when becoming a master. My license still shows both.
The business must obtain a contractor license to do business as a contractor, and must employ a master in the specialty trade(s) they wish to perform. The contractor license stays active unless allowed to lapse, but need not be forfeited for the master to work elsewhere.
However, the contractor business may not perform in the specialty trade unless there is still a master employed. My business is licensed for home and commercial improvement contracting also, which do not require employing masters unless performing those specialties.
I can perform as a journeyman if I wish to avoid the responsibilities a master must bear, as long as I m willing to accept journeyman's pay.
Yes, C10 Masters must direct hire JW Cards, or apprentices in training, when on their payroll.a C-10 cannot work for another C-10 without a journeyman
license.
They still might reciprocate a master/contractor as a journeyman, they just won't directly reciprocate master to master.The only justification I could see to keep both is that it seems more likely other states might reciprocate the Texas Unrestricted Journeyman License but may not reciprocate the Texas Master.
Since I do not plan on working outside of Texas, I let my UJM expire and renew only my Master License.
