JJWalecka
- New England
I read this on Tom Henry website.
?The example below shows two buildings with a 3-way switch in each building controlling the light on one building which also has a duplex receptacle which is hot all the time. To correctly wire this circuit it would require four circuit conductors and an equipment grounding conductor. With the Carter system the duplex receptacle is hot all the time and the two 3-way switches will control the light. Only three wires are used instead of four. With the Carter system the duplex receptacle is hot all the time and the two 3-way switches will control the light. Only three wires are used instead of four."
Does anyone know who this Carter system was named after? Was this common practice years ago?
JJ
JJ
