cash register data port?
Some do.
Some are standalone.
Some are wireless (Wi-Fi).
Some networked systems use Ethernet (CAT 5 or 6 or fiber), others use proprietary communication links.
Most cash registers are standalone, however many businesses are switching to touchscreen POS terminals.
Also keep in mind that most businesses will have a credit card terminal colocated with the cash register. These usually require a phone line, however most units also accept an ethernet cable, which can be used to connect to broadband internet. This results in much faster processing.
If possible I'll run both (two CAT5) so the credit card machine can fail over to dialup if the internet goes down.
My experience is the opposite. :)
Every register I have done, and I have done tons of them, takes a data line of some type. Mom and pop stores may have stand alone but any chain type retail will be tied into a network. This is for pricing updates, sale pricing, inventory control etc.
I have never brought a phone line to a credit / debit card reader, they have always tied into the register equipment or been a cat 5 back to the data switch.
So as far as the OP the only way to find out what you need is to ask the people supplying the equipment. We usually run 3 or 4 cat 5e cables to each point of sale and they use 2 of them leaving the rest as spares.
Could someone explain why a coax cable would be requested to be installed instead of a cat 6?
I'm going to find out for sure tomorrow but...
Customer said Verizon wants plenum rates coax cable ran. Then they will be mounting thier modem in theIT room.??
I ordered cat 6 plenum rated cable. Planed on bringing it to the IT room. Have a RJ 46 plate at the register location.
Not that similar with telecommunications.
The original cable connected IBM sales/ business terminals used twinax instead of coax and ran an IBM proprietary synchronous communication protocol. Other makers used other proprietary protocols over coax, before it became common to use IP.
Ethernet over coax (first fat and then thin) came long before twisted pair Ethernet.
well, their hardware is coax based, so that is what you pull....
i'd upsell the customer to add two cat 6 lines with each cable
you pull, so when they flush this bozo late 80's architecture, they
will have something for connectivity.
jesus... this sounds like 16 MHZ token ring from 1988......
maybe they can make it work with a 2400 baud modem as well....
K-Mart used that system it was a booger to troubleshoot.
A lot of smaller Chain stores will only have a couple registers that need to be networked. They will install the modem and a small switch under one register, and the setup team will just use patch cords within the counter.
my guess is that Verizon is asking for the coax so that they can install a cable modem. you may want to ask about a few cat 5e for voice.
Why is Verizon involved with POS or cash register installations??
Have a RJ 46 plate at the register location. Not that [fam]ilar with telecommunications.
I guess not. What the heck is a RJ46 and how would it support coax??
-Hal
