mickeyrench
- edison, n.j.
I have alot of cat # 3 cable i got from someone and was wondering if it can be used for phone wiring or door bell wiring?
Billy_Bob said:As to doorbell wiring, many doorbells these days are electronic with speakers and will pick up a "60 cycle humm" if the wiring is run by electric lines.
So might be a good idea to use shielded wiring.
Of course if they are installing an old fashioned "ding dong" mechanical type doorbell, then no need for this, however they might replace it in the future with a fancy electronic Westminster chime job which will then have a low "hummmm" constantly...
hbiss said:I have alot of cat # 3 cable i got from someone and was wondering if it can be used for phone wiring...
What the heck do you think it's for?? If you are using CAT5 you are wasting money and time.
-Hal
DP_Fuse said:Cat5 has a better NEXT (near-end cross talk) resistance. It can actually carry a higher quality signal. It also has a much higher frequency range (16Mhz for cat3 and 100-350Mhz for cat5 and cat5e). Although most phone equipment's compression is far below the cat3 standards, it's still better practice to use cat5e over cat3. There is little to no difference in price.
If I had bunches of cat3 laying around though, I'd use it for phones. Especially in residential installs where I was pretty certain they wouldn't need the higher bandwidth potential of cat5e. I'm still not certain how either cat cable could be more or less efficient on time though?![]()
dp
DP_Fuse said:Does my post offend? I'm not trying to step on any toes here.
I shouldn't quit my day job? You mean my I.T. consultant/network engineer day job? Thanks, I'll take that as a compliment.
I have no doubt you already know this stuff, but other's might find it informational. I typed these up at different times a while back in the forum:DP_Fuse said:Cat5 has a better NEXT (near-end cross talk) resistance. It can actually carry a higher quality signal. It also has a much higher frequency range (16Mhz for cat3 and 100-350Mhz for cat5 and cat5e).
The physical difference among twisted-pair cables is the number of twists per foot. All cables will "carry" data at any speed, but the receiving circuitry cannot separate the desired data from induced noise if the noise is present, and not in phase, on both conductors.
The receiving circuitry uses a technology called "common-mode noise rejection." Any electrical signal that arrives equally, and in phase (common mode), on both conductors is ignored, and only the out-of-phase signals (differential mode) are processed and passed on.
Induced noise on a twisted pair that strikes both conductors equally can be rejected. Because higher frequencies have shorter wavelengths, the tighter the twist rate, the higher the frequency of induced noise that can be rejected, which means a higher reliable data-transfer rate.
Technically speaking, the tight, consistent twists assure that both conductors of a pair pick up induced noise as similarly as possible, so the common-mode noise-rejection input circuitry (typically differential op-amps) can reject it.
All conductors can carry high-speed data streams. The greater the number of twists per foot, the higher the frequency (i.e., the shorter the wavelength) of noise that can be rejected, and thus the greater the reliable transfer rate.
Ever noticed that UTP cable pairs are twisted at slightly different rates? That's to minimize cross-talk among pairs in a given cable, as well as others in close proximity. UTP data cabling is practically immune to 60-Hz interference.
Added: By the way, for POTS (Plain-Old Telephone Service), CAT-3 is all that will ever be needed, and is all I ever run, for voice-only lines, unless I'm paid to run CAT-5e (or better) instead. We'll have optical before that's needed.
hbiss said:I wouldn't worry too much about that happening. They can push that crap all they want but people are finally wising up and seeing it for the snake oil it really is. It winds up costing them much MORE money than what they replaced.
-Hal
jcassity said:I have a decent question,, is your power source ac or dc to the door bell ringer?
Yes, 16vac to be approximate.iwire said:Most are AC.
