Is Cat5E rated to be run in the walls of a commercial building without conduit?
laketime Senior Member May 31, 2010 #1 Is Cat5E rated to be run in the walls of a commercial building without conduit?
V Volta Senior Member Location Columbus, Ohio May 31, 2010 #2 As long as it is type CM, CMR, or CMP, and it complies with 300.4(D) and 300.11 per 800.24. Good design to comply with 300.4(B) too . . .
C crazyboy Member Location NJ May 31, 2010 #3 It depends upon the type of insulation that is on the Cat 5. There is various different types with different ratings.
