There are some specifications for installing. See the informational note which refers to ANSI/NECA/BICSI which could be considered code.
800.24 Mechanical Execution of Work. Communications
circuits and equipment shall be installed in a neat and
workmanlike manner. Cables installed exposed on the surface
of ceilings and sidewalls shall be supported by the
building structure in such a manner that the cable will not
be damaged by normal building use. Such cables shall be
secured by hardware, including straps, staples, cable ties,
hangers, or similar fittings designed and installed so as not
to damage the cable. The installation shall also conform to
300.4(D) and 300.11. Nonmetallic cable ties and other nonmetallic
cable accessories used to secure and support cables
in other spaces used for environmental air (plenums) shall
be listed as having low smoke and heat release properties.
Informational Note No. 1: Accepted industry practices are
described in ANSI/NECA/BICSI 568-2006, Standard for
Installing Commercial Building Telecommunications Cabling;
ANSI/TIA/EIA-568-B.1-2004 — Part 1, General Requirements
Standard; ANSI/TIA-569-B-2004, Commercial Building
Standard for Telecommunications Pathways and Spaces;
ANSI/TIA-570-B, Residential Telecommunications Infrastructure,
and other ANSI-approved installation standards.
