Cat 6 Cable
You can use two RJ45 connectors and a coupler. Depending on what data speed is needed through the cable that might be adequate. They also make punch down blocks to splice two cables together.
As Tom said, pulling a clean home run is the best solution. If that isn't an option, then properly terminate the end that needs extended (my preference would be with a keystone), and run the additional length (again with proper terminations, keystones in my world, at each end), using a short patch cable in the middle. You'll end up with:
Original end - original wire - new keystone - patch cable - new keystone - new wire - new keystone at the final location.
Keep in mind that the key-patch-key will make your effective run longer than it would seem, and 328ft can creep up on you really fast.
RJ45 and couplers can work, but we've found them to be somewhat unreliable, especially when bent near the connector. Just last month I had to cut off and re-terminate several new CRAC links because the vendor used stranded IDC connectors on solid CAT6. Punch-downs are a non-starter unless this is telephone/T1 level stuff.
If you had to extend existing cables how would that be done? Can you even splice or terminate it somehow and extend it?
To relocate a network closet or server rack I use a cat 6 110 punch down block, like this Leviton one
If its one or two cables I would as others suggested pull a new run.
Rather than have the customer specify the copper cable type its better to specify the network design speed, for most offices its a 1000BASE-T.
