You betcha, brother. If the customer already upsold themself, farbeit for me to talk them out of it. "Yessir!"stickboy1375 said:And thats what he shall get... :grin:
The "A" configuration of CATx wire termination conductor insulation color matches Plain Old Telephone conductor color.Sierrasparky said:certain patch panels such as the ones used in Leviton Structured media components require use of only A ... I don't see why
sparky59 said:i have a customer that wants cat 6 for his computer networking in a commercial building. does cat 6 terminate in an rj45 jack and use the 568-b configuration just like cat 5e?
Not quite. The spacer maintains the relative positioning of the pairs as the cable is routed around bends and such, but the main difference is the number of twists per foot. This is by me from another thread:benmin said:the only differance between cat 5e and cat6 is that cat6 has a insulator seperating the 4 twisted pairs.
LarryFine said:Technically speaking, the tight, consistent twists assure that both conductors of a pair pick up induced noise as similarly as possible, so the common-mode noise-rejection input circuitry (typically differential op-amps) can reject it.
All conductors can carry high-speed data streams. The greater the number of twists per foot, the higher the frequency (i.e., the shorter the wavelength) of noise that can be rejected, and thus the greater the reliable transfer rate.
Ever noticed that UTP cable pairs are twisted at slightly different rates? That's to minimize cross-talk among pairs in a given cable, as well as others in close proximity. UTP data cabling is practically immune to 60-Hz interference.
stickboy1375 said:I honestly don't think it matters as long as you keep everything the same... but I also don't see any advantages in using Cat6 either...CAT6 comes at a significantly higher price tag than CAT5 or CAT5e, and today's applications simply can't take advantage of CAT6's better performance. However, if wiring a home or building for the long term, one may still consider using CAT6.
What will be the point where optical will be the better technology over UTP?tallgirl said:The standard for cat7 is now being, uh, standardized and it will find applications sooner or later as well.
LarryFine said:What will be the point where optical will be the better technology over UTP?
It is no more dificult to install than CAT-5 and there are terminations that are almost as fast and as easy as those for CAT-5.And when glass isn't as fragile and hard to install as it is.
benmin said:The 568a configuration is:1 blue pair, 2 orange pair, 3 green pair, 4 brown pair. This works best with home wiring of structured media. It is consistent with phone wiring.
The 568b configuration is:1 blue pair, 2 green pair, 3 orange pair, 4 brown pair. This is the standard for networking. but if it was used in a home structured media set up it would swap the orange and green of a phone so that line 2 would be line 3.
As long as you terminate each end the same (568a or 568b) for a network, you'll be fine
Rjrus said:If, as in most residential applications, the network cabling is just being used for internet connection--keep things in perspective. The bottle neck is not the network it is the internet connection.
