Re: Category 3 cable and RJ11 jacks
I?m surprised Hal didn?t jump on this question.
Long day too.
The category of the cable has nothing to do with the number of pairs although I don't think CAT 5, 6 or 7 can be had in anything but 4 and maybe 25 pairs. As has been said, CAT 3 which is only used for voice today can be had in from 2,4,6,12 to multiples of 25 pairs.
The CAT 3 spec requires, among other things, that each pair be twisted. Don't expect CAT 3 to be twisted nearly as much as CAT 5 though and that's a good thing because it makes termination easier. We always prefer to use CAT 3 for voice because you don't have to untwist tightly twisted pairs to terminate them.
An RJ-11 jack is not a 4 pair jack, it is 1 pair jack. You need to brush up on jack designations. The designations relate to how the jack is wired, not necessarily how many pins it has. A jack with 4 pairs would be a RJ-45 and would require an 8 pin jack. You wire these as 568A, 568B or USOC depending on use.
Check out something like the back of a Leviton telecom catalog for all this information.
-Hal
