supergeek
- Los Angeles
Hello everyone,
Well, I ran across this today and wondered what might be causing it. All the neutrals near the top of the neutral bar are badly burned, yet the bottom neutrals look ok. The main neutral conductor looks clean and the connection is tight. There's hardly any load on the panel - 3 phase 120/208 - because part of the building is being renovated.
I tightened the screws on the neutral wires a little, but they weren't horribly loose. Very little load on the neutral either, under 20 amps when I took the reading. Also, the neutral bar wasn't overly warm, even in the 'problem area' And no signs of water damage or leakage into the panel either. Anyway, thanks in advance for any ideas you might have. The property manager has decided to replace the entire panel, but I don't want it to keep happening.
