T tadziu Member Feb 22, 2006 #1 What is the height range of a Main CB Panelboard supposed to be, in a residential building. Can not locate info in NEC Code Book.
iwire Moderator Staff member Location Massachusetts Feb 22, 2006 #3 Re: CB Panel Board Height. Panels can be as high as you want. The handle of a breaker must be 6' 7" or less.
roger Moderator Staff member Location Fl Occupation Retired Electrician Feb 22, 2006 #4 Re: CB Panel Board Height. It can be from ground level to the highest point of a breaker handle being 6'7", the panel enclosure itself can be as high as it needs to be, see 404.8 Article section 550.32(F) does have a minimum height of 2'. Roger
roger Moderator Staff member Location Fl Occupation Retired Electrician Feb 22, 2006 #5 Re: CB Panel Board Height. Morning Bob. Roger
iwire Moderator Staff member Location Massachusetts Feb 22, 2006 #6 Re: CB Panel Board Height. Originally posted by roger: Morning Bob. Roger Click to expand... Good Morning Sir.
T tadziu Member Feb 22, 2006 #7 Re: CB Panel Board Height. Thank's Guys. 6'7" to the Breaker handle is what I was looking for.
