Designer69
if you guys would be so kind, what are some of the differences/benefits/disadvantages of using a circuit breaker over a motor circuit protector or vice versa.
There are traditional US style MCP's which are not much more than a circuit breaker with a magnetic trip function only. But, there are also devices which Europeans call MCP's and the traditional US name is Manual Motor Starter. Which one are you asking about?if you guys would be so kind, what are some of the differences/benefits/disadvantages of using a circuit breaker over a motor circuit protector or vice versa.
the US style mcp and the application is to protect a 25 HP fan motor for a cooling coil which is used to cool a bus duct. thanks
so if you use a thermal magnetic CB in a combination starter would you still use a thermal overload relay or is the thermal element of the CB sufficient?
