CCTV grounding on a Pole
For 17 years I have trouble shot lightning issues and grounding differential with CCTV cameras, and 90% of all lightning issues and differential problems are due to cameras being on a metal pole, and the power source is located at the pole. Lets think about ground loops. More then one ground, is a ground loop and multiple path ways for lightning to come up through ground, will go out the other ground. Now if lightning hit the pole, the camera is toast. Reason: SMT technology with low pf, SMT, capacity cannot stand EMI much less EMP. A pair of socks on a rug would knock out a camera. We are just focusing on the camera. What about the rest of the system? Is it not true that the shield is referencing to ground at the DVR. Is it not true that the DVR AC power is a different ground then the AC power for the 24V AC at the camera and the case ground of the camera? What do we have? We have three different grounds. Am I not correct? We have to get rid of the ground loops. First we have to look at the system and understand our goal is single point grounding. The question is, how are we going to do this. You have to look at before market approach and after market approach. To do it right, is to do it right during the before market approach then trying to band-aid it on the after market approach.
Here is the test:, you have three ground loops, get rid of two of them if you can. Lets add another piece to the puzzle. All CCTV cameras must have coax surge suppression, but do you dare to follow the direction the manufacture recommends, if you are trying to achieve single point grounding. But remember you have two ground loops you have to get rid of, and not add a ground loop to the equation. I have the answer, and it is true when Mike said, NEC does not have an answer to this dilemma. I just want to see what people think.
You think this is tough, wait until someone asks about Gate Access.:wink:
