Cedar Hot Tub Assembly
How would one protect a hot tub assembly that has two connections. One I can do which is the pump and control panel. The other connection is to the heater which is 240V/1PH, no neutral required as its purely resistive.
Pump/Controller = 11A - Protected with 20A/240V GFCI Breaker
Heater assembly is 11KW/240V/45.8 amps.
All feed from 100A/240V subpanel. No manufacturer makes a 100A/240V GFCI breaker.
Keep in mind two connections to single complete assembly.
Thanks in advance
