Tulsa Electrician
- Tulsa
- Electrician
There is four services on a single building.
As part of the GES the four service all have a 3/0 GEC to the CEE.
The water service is plastic.
There is two rod electrodes driven at each service.
The metal part of the building has steel columns. (1 service)
The rest of the building is wood framed where the other services are located. (3 services)
From one service they have a GEC ran to building steel. The only tie to all four is the CEE.
Question:
Since the CEE is the only tie ( common) to the four and only one has a GEC to the steel. Would the CEE common be considered a violation under 250.53 (C) 2020 NEC.
Question:
