Re: ceiling fan rated boxes
E.C.-what was in the job plan?
Were you replacing the fans?
Did you have to take them down in order to do the work you did contract for?
An inspector usually makes a call like that when the old work is involved in some fashion with the new work.If you have a feed available for a lite you're installing ,but its coming out of an old ,overfilled box ,you can't just tap in and say "it was like that when I got here".It becomes your responsibility as the last Elec. of record , to correct that situation-because if that house burns down ,for whatever reason all the Ins. people see is your name as the last guy who worked there.
These fans may have stayed up for 24 yrs,but if the work you did there in any way involved them,and one subsequently falls down on someone ,it will be your head and the inspectors on the block because you didn't bring it up to code and he didn't make you ,when it was apparent that the exposed old work was not up to current standards.
