jeff48356
- Livonia, Michigan
I'm just wondering what your opinions are on this:
Do you think ceiling fan boxes should be required by Code to be wired with 3-wire cable, rather than 2-wire? I often find myself needing to replace the 2-wire cable feeding a ceiling box with 3-wire because the customers want to install a fan. 3-wire cable is required in order to be able to operate the light and the fan separately from the wall without using pull-chains on fans. If the builder doesn't want to install a fan right away, that's fine -- just cap off the red at the switch and ceiling boxes. This way, if someone else wants to install a fan in the future, they can do so without rewiring anything.
Whenever I wire a room that ceiling fans are commonly used in, I ALWAYS run 3-wire cable and a fan-rated box, whether the end customer intends to install a fan or not.
