Ceiling fan with remote and insteon dimmer keypad
ingeborgdot
New User
Kansas
Retired
I have an insteon dimmer keypad. If you are unfamiliar, it is a keypad with 8 different keys. Each runs different lights and can be programmed to do different things. I have a ceiling fan that I am replacing. It is setup that the fan is powered on all the time. I just have to pull the chain to turn it on and set speeds. The light turns on and off with the keypad on the wall. It is a dimmer and has a slower ramp rate when it turns on.
I just bought a new fan with remote control, but it is not going to work. It says it needs to have a switch that is not a dimmer switch. I don't know if there is a ceiling fan with remote that can bypass the fan control and have constant power to the fan out there. If there is one, I can't seem to find it. It looks like the old pull chain is the only way to go. Shoot.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
