ceiling fan
dekies
New member
I have simple question reqrding the wiring of a ceiling fan. In the 99 NEC it is considered an appliance. Can it be wired to one of the general purpose circuits, or does it require its own seperate circuit, or if its less than some % of the ciruit you use general purpose and if is is more than some % it is wired separtely? I haven't found a clear definition for this, might not be looking in the right place?
Thanks.
Re: ceiling fan
You may have to go to your local inspector or electrician to find this requirement. I would say that the ceiling fan is a general purpose load on the system there by allowing for connection to a general purpose line. The percentage of load on the line may tell you that the load (ceiling fan) may need another general purpose line run for it but not just it.
jro
Re: ceiling fan
A cieling fan on a seperate circuit :eek: :eek: :eek: ! You would never get a red tag or be run out of town for installing a cieling fan on a general purpose circuit, MY O MY ARE WE READING TO MUCH INTO THE CODE, take a look up at your cieling what is the thing spinning around in the center of your bedroom cieling blowing air, HEY ITS A CEILING FAN!!!!!! :eek: :eek: I apoligize to all and everyone but, you know,.......... yea you know.
[ May 22, 2003, 08:24 PM: Message edited by: jro ]
