chevyx92
- VA BCH, VA
Can all ceiling fans be speed controlled through a "Fan Rated" rheostat? Say your average fan from home depot or lowes. Or does the fan need to be rated for speed control?
Jim W in Tampa said:... you might hear huming
dbuckley said:A rheostat might be OK, but a light dimmer using a triac will almost certainly cause buzzing, as the chopped waveform from the dimmer causes the fan magnetic compionents to rattle a bit.
The trouble with a (real) rheostat is that it gets hot; most fan controllers use switched capacitors, which reduce the fan speed without buzzing or getting hot.
chevyx92 said:Can all ceiling fans be speed controlled through a "Fan Rated" rheostat? Say your average fan from home depot or lowes. Or does the fan need to be rated for speed control?
celtic said:Why is that?
RedHouse said:Cause it doesn't know the words!
mikeames said:You cannot control AC motor speed buy dropping the voltage.
