esox39
- Chicago, IL
I have a situation. I have 2 non reversing industrial ceiling fans. 1 speed controller operates both. 120V .70 amps. Fan A is 40 feet from the speed controller. Fan B is 55 feet from the controller. Both are mounted on 10' ceiling. When we turn on the fans, Fan A spins dramatically faster than Fan B. The manufacturer sends a new fan. We replace Fan A with the new one. Same results. We replace Fan B with the one we took down and again, same results. Wiring is in conduit, with switch leg conductors for general lighting. We re pulled conductors to be sure of proper wiring and no crossed neutrals. Same results. Does anyone have any insight as to why 2 fans 15 feet from each other run at 2 different speeds? Thanks for all the help.
Ron
Ron
