For a ceiling mounted projector that is provided with a power cord to plug into a receptacle outlet, is it allowed to snip the end of the power cord to hard wire it into a ceiling junction box since flexible cords aren't permitted above a hung ceiling?
I'm not quite sure I understand the question. Flexible cord is flexible cord whether it's got a cord cap on it or not.
In my opinion no it is not.
We install the outlet in the ceiling tile facing down using a 4" square box, an appropriate plaster ring and a Caddy 512HD support bar.
Let me clarify, I meant to write flexible cords aren't allowed to be plugged into receptacles located above the hung ceiling.
So for a ceiling mounted projector, I wanted to know if the end of the power cord that comes with the projector if that could be snipped so that it was hard wired into a ceiling mounted junction box and not a receptacle.
.The the answer is no. It's not that you can't plug anything in, you just can't leave anything plugged in. Flexible cord is not allowed to be conceled above a suspended ceiling.
'Tis what we do.Thanks. Looks like the acceptable solution is mount the receptacle in the ceiling tile.
