hhsting
- Glen bunie, md, us
- Junior plan reviewer
I have cell tower which requires plan review permit as they are adding new antenna equipment, RRHs on it.
Please assume cell tower is under NEC.
Please also note that the cell tower equipments up top is fed from rectifier at cabinets bottom of tower which converts AC to DC. The system voltage of the equipment on cell tower is 48vdc, 2 wires.
Attached sketch shows one sector of cell tower that has antennas and RRHs casings bonded to the sector ground bus bar on tower using wire bonding jumpers. The ground bus then has grounding electrode conductor from ground bus bar to grounding electrode ground ring
I am having hard time finding how to size the bonding jumpers in the attached sketch labeled B1 that bond from cell tower equipments metallic casings to sector ground bus bar using NEC 2014 for 48VDC system? I looked in NEC 2014 section 250 part VIII but I was not able to find how to size for DC systems bonding jumper. Can anyone please help?. Especially for cell tower
