Johnaorr
New member
- Syracuse, New York, USA
For many small shops, the high leg delta system is preferred over the wye system because the machines get 240 volts three phase and not 208. But the delta should be a full three-transformer delta connection, and not a two-transformer open delta or Vee connection, which gives quite poor voltage regulation under either unbalanced loads or high loads.
Why does an open delta setup give you poor voltage regulation and nuisance tripping due to higher loads?
