malachi constant
- Minneapolis
Doing an audit for a multi-family apartment. (80 units, mostly elderly, though it is not assisted living/nursing home anything like that.) The individual apartments do not have laundry within them. There is a central laundry room on the ground floor with three coin-operated washers & dryers.
I noticed the washers are not GFI protected. They are within 6' of the sink and I will be recommending their maintenance staff get those swapped out.
I also noticed they do not have any general convenience receptacles in this room. There is a folding area but no receptacle for ironing. I initially brought this up as a code issue but since realized the "laundry receptacle" requirement is only for within units. Am I correct that there is no code requirement for a "general" or "laundry" receptacle in this room? They are understandably not interested in putting it in if it is not required.
This is nowhere near the biggest item on the list, but now that I've opened my mouth about it I feel obligated to chase down the correct answer. Thanks!
