Is there a minimum voltage rating on a wire nut? I am getting ready to order
some ceramic wire nuts that are rated for 300 volts, were as the best I can
tell a regular wire nut is rated for 600 volts. We plan on using these
ceramic wire nuts on 480 3 phase heaters.
That?s how I felt. The concern came from the fact that everything else I work with is rated for 600 volts. I didn't know if possibly the wire nut was more porous this is why the lower voltage rating due to it's potential to hold moisture.
If the conductors come apart under load, wouldn't the voltage across the connection be 480V?
IMO the voltage rating is inadequate for the application since the potential from conductor to conductor going to the heater is 480V, not 277V.
