Peter P.
- Meriden, CT
I have a friend who's having a flickering CFL problem.
The bulb in question is in an outside fixture on a side porch.
It flickers at all temps.
The front porch has the same bulb but doesn't flicker.
We replaced the bulb but there was no change.
The switch operating the CFL is not illuminated (which I've read can cause the flickering), but IS in a 4 gang box with three other switches (presumably in parallel), one of which is a dimmer.
I'm wondering if the dimmer, being in parallel with the CFL switch, is the problem. I don't know what the dimmer operates but it could be a fan or incandescent lamp.
Could that dimmer be swapped to a florescent capable model even though it might be running a fan or incandescent bulb?
I know the easiest solution is to just replace the CFL in that fixture with a different type bulb, but it would be nice to have an explanation for this light's behavior.
Thanks for reading.
Thanks for reading.
