Our eyes do not respond equally to different wavelengths of light. I replaced a high pressure sodium lamp in my back yard with an identical wattage metal halide and the difference was stark. Although their output in lumens is allegedly similar, the yard looks much brighter with the metal halide, even though your test might indicate the sodium light was "brighter". The sodium light is monochromatic and has very poor color rendition, but might well show a higher output with a CdS sensor. If you look at an infra red or ultraviolet source, you could get very high brightness, but the light produced is invisible to our eyes.
Sodium is not monochromatic, unless you're talking about LPS SOX, which is not something you find normally. Uncorrected CdS sensor is pretty much useless for quantifying visible light. [/quote]
If you were measuring output in radiometric output (watts for output and brightness in mW/m^2) then you're correct.
Radiometric measurements are used for UV and IR sources, but they're not used for general lighting. Photometric measures are used instead, which means they're weighed to human eyes. Lumen is a unit weighed to human eye response and well made light meters respond to best approximation of human eye sensitivity curve.
You measured the brightness emanating from a point on the lamp. If extended in all directions around the lamp in three dimensions, all measurements surely would not be equal. If all of those measurements would be integrated, you could determine the relative light output for the lamp. But that does not address the effects of differing wavelengths (color).
Maybe I wasn't clear earlier. I have found that replacing a 60 watt incandescent with a 4100K 13/14 watt CFL in most fixtures in my house are roughly equivalent in apparent lighting. Replacing a 100 wattt incandescent with a 24 watt CFL is clearly not. This is only my perception. The CdS cell readings would surely differ.
Of course CdS will differ, because uncorrected CdS is horrible at emulating human eye response. High accuracy light meters are expensive. Gossen Mavolux is like $1,800, a CdS cell is like 25 cents a piece.
gar said:
Interesting site:
http://www.fullspectrumsolutions.com/whats_wrong_with_cool_white_lamps.shtml
But fails to really define what is a full-spectrum fluorescent's spectrum.
That's the company that raised hell over "made in the USA" over Everlast. That company is full of crap. They're the one who offers 3300 lumen 32W 91 CRI T8 lamp, something that even top brand names can't make.
That website has a link to some lab test for some of their products, but that lab doesn't appear to be referenced anywhere else. When I asked for verifiable lab result, this is what they tell me
"Because we have a patented proprietary blend, I am not sure how much information I can release to you"
Patented means that the protected art is published, in exchange for legally protected right. These guys won't even cough up the US patent # of the supposedly "patented" technology.
