Nobody900
- Los Angeles
- Electrical Engineer
If I am not supposed to post here, my apologies, and feel free to delete this post. I own a home that was built about 1994 and has two Challenger service panels. The label in the entrance panel is no longer readable. It has a meter fitting in the top left with a long empty box below it closed with a screw on cover. The breaker section is a long, single box on the right with a top hinged cover and a single column of breakers all marked "Challenger" so I assume this is a challenger panel. The sub-panel in the garage is a Challenger SL20(20-40)CCT with mostly Challenger and HB breakers. While trying to learn more about this equipment I found a lot of conflicting information on the Internet (surprise).
Some information states the panels are dangerous and have to be replaced. Some state the panels are a good design, but the breakers frequently fail to trip at rated load and need to be replaced while the panel needs to be inspected for evidence of arcing and overheating. Some state there are no issues with Challenger panels. I purchased the home in 2005 and nothing was noted by the inspection technician I hired. I have had three licensed electricians perform work in the home and no one noted an issue. Yesterday I contacted the last one who worked here and he stated he had no knowledge of issues with Challenger equipment.
Can this forum provide me information on what issues may or may not exist with Challenger equipment of this 1994 vintage? I'm an electrical engineer and savvy enough to not "learn" by working on things that can cause fire or death, so any necessary remediation will be done by a licensed professional. I'm just looking for advice on what courses of action I should be considering. Thanks in advance and I can post pictures if anyone wants then.
