I am trying to come up with a way to install a chandelier and lift. The chandelier will need to be connected in the center of the circular cutouts as seen in the picture. My thoughts were to fabricate a bracket that will mount in the center with a pulley located directly above where the outlet box will mount. The mount will be about 30' feet above floor level and will need to be able to support about 200lbs max. I have been looking at the Alladin light lifts and was wondering if any of you guys have ever run into a similar install. Any ideas you may have would be much appreciated. Thanks
