- New Jersey
- Journeyman Electrician
Does this finally clear up installing more than three conductors in conduit bodies which are marked with a specific size?
For example:
LB says "3-#2 AWG conductors" I can use 4-#4 conductors when the calculations proves that the 4-#4's have a cross sectional area less than or equal to 3-#2 XHHW conductors.
For example:
314.28(A)(3) Where the permitted combinations of conductors for which
the box or conduit body has been listed are less than the maxi‐
mum conduit or tubing fill permitted by Table 1 of Chapter 9,
the box or conduit body shall be permanently marked with the
maximum number and maximum size of conductors permit‐
ted. For other conductor sizes and combinations, the total
cross-sectional area of the fill shall not exceed the cross-
sectional area of the conductors specified in the marking,
based on the type of conductor identified as part of the product listing.
Informational Note: Unless otherwise specified, the applicable
product standards evaluate the fill markings covered here based
on conductors with Type XHHW insulation.
