I have an existing Siemens surface mounted panel that needs to be relocated. The architectural design is limiting where I can hide a surface mounted panel, so I was wondering if it could be changed into a flush mounted panel with minimal costs. From what I understand, it's the cover plate that differentiates a surface mounted panel from a flush mounted one. Are there kits available that can make this change? Thanks!
