frani said:
I'm wondering how people in the electrical field (i.e. electricians inspectors and others) think the electrical field will change in the next five or ten years.
The current trend emphasizing safety will continue. The cowboy that could lick his fingers and touch energized parts to diagnose a circuit will become apocryphal. Both installers and end users of premisis wiring systems will be safer following new procedures and using new, safer materials.
frani said:
Will we be installing solar panels on all new homes and businesses?
"All" is a long stretch, in my opinion. Solar panels as a central power source for a building is still complicated and expensive. I do note, though, little loads, such as landscape lighting, address numbers, etc., can be, and are, directly supplied by little solar panels, and are commonly available in the market. Such little loads are a growing segment of the "off-the-grid" share of the market.
frani said:
Will there be a new energy source that will change the way we wire and the voltages we use?
As mentioned above, fuel cell technology is exciting.
I would also keep an eye on the hybrid passenger car and electric passenger car market. All of these vehicles need to be recharged, and they sit idle once charged, a significant amount of the time. The fully charged cars are a potential "distributed peaking power resource" that can offset the need for some of the bricks and mortar power plants.
Fuel cell powered cars, potentially, will not only be a source of stored electricity, but might also be a distributed generator source, helping to reduce further the number of required bricks and motar power plants.
frani said:
Will we lose jobs because of prefab housing?
Prefab housing still has to be set on the ground and hooked up to a community's utilities. National and local codes and ordinances will still have sway, and require local work, outside of a centralized manufacturer's location. The distribution of jobs will shift a little, but that is part of a dynamic marketplace, anyway.
frani said:
Will being energy efficient change the way we wire?
The real changes that energy efficiency makes is in the loads, the things, the equipment, that use energy. The wiring that I install will not change substatially, if at all, because of energy efficiency. My wiring is only the connection to the energy, its not the user of the energy. The dramatic changes will be in the equipment connected to the wiring. That equipment is not covered by the National Electrical Code.
