Can you change the size of conduit underground without installing a handhole?
I would have said no, you can't pull wire through a reducing fitting, but then I remember seeing a "Y" fitting that someone posted a picture of. If you can pull through a "Y", I would assume you can pull through a reducer.
We have a case where there is an existing 1.5" conduit. Contractor needs to connect this to a pole foundation they installed, and apparently they put 1" in the foundation. They say they can't connect the two conduits unless we pay them to add a handhole.
If it matters, the main run is 1.5" PVC, with (3) #10 wires, and the reduced conduit size is 1".
