changing panels
nicknorth
If you where changing out serval panels from 175amp to 200amp and these panels where feed from a single older service. Would this break any code issuses?
Re: changing panels
The wire is rated for 200 amp feeding the panels. The service gear I'm not sure what it is rated for, but I'm not adding anymore load to this. The service gear is old with no main disconnect.
