I had an estimate today to do a service change. When I got there the homeowner was in a big hurry to do the job and I found out it was because there was no hot water. There was nothing really wrong with service other than being kinda old and the water heater was in front of it. I suggested we just fix the water heater for now since changing the service would be a big pain. At the time I was thinking the problem with the water heater was probably a fuse or something but when I left I realized it was most likely elements.
Now I don't usually change elements but I was thinking I would start with this job. I called a plumber friend up and he said he usually doesn't change elements and just sells them a new water heater. He said if it's more than 7 years old it should just be replaced. Is this true? Is there anything I need to look for to assess condition of the old water heater?
Is there any issues with changing the elements I should be aware of? Will it drain OK? I hear sediment builds up in these heaters. Will the stirred up sediment cause the water at the faucet to be black? Are the elements ever stuck in there from corrosion.
