DM2-Inc
- Houston, Texas
We had a helper installing some wire for a fire alarm system. Apparently he was new enough that he couldn't recognize the difference between 16 AWG and 18 AWG (it could have been 14 and 16...I'm getting mixed information from the field). As a result, one circuit has one leg at the larger AWG and the other leg at the smaller AWG. There is a fair amount of work in involved in correcting the mistake and I'm struggling with replacing the wiring or leaving it alone, considering the cost in labor, not to mention the lack of professionalism.
I believe there is a section of the NEC which prohibits stepping down a circuit more than 1 wire size, but can't remember where I found this. I have found nothing that specifically states that you can't have have on leg of the circuit installed with a larger wire than the other leg.
