Characteristics of Short Circuits
Compare building power monitoring data to fire panel & sprinkler data, then compare time stamps.
In absence of monitor data, security cameras, or arson evidence, just look for impaled cables, or overheating from conduit-fill, derating, or listing violations; document and prosecute.
When the EC's insurance carrier refuses to pay, they may help reveal why the contractor was disqualified, criminal, and a liar; even if he wasn't responsible. ;)
This one is obvious...
The story about this picture...
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/2008/5/Electrical-fire-GFCI.htm
why do you say this is obvious ? Couldn't this have been caused by a) a lightning strike b) a poco spike c) bad device or d) other ? (I read the article but it doesn't convince me of anything)
Posts 3 and 4 are your answers.
The use of the proper equipment, training, and methods would be hard to learn on an internet forum.
I would point out the forum rules here,
Rules, Policies, and Disclaimers
No information gathered from this web site shall be treated as being the opinion of an 'expert witness, and you do not have anyone's permission to present such information as evidence in any type of legal dispute.
This is not meant to imply that you are looking for evidence or an expert witness, but I did want to mention it.
Roger
I read the posted link. It sounds to me like the 2nd electrician came in and "fleeced" the owner. His comments are not that of a professional - gasketing is required - that is news to me.
i'd agree..... gasketing? who are we kidding here? gasketing, in a bathroom?
if you look at the smoke path, it looks like the device cooked off pretty well.
a small amount of very dense smoke from burning plastic. i'll bet a nickel
that the source of ignition was within the GFCI, seeing how the smoke
volumn was small, dense, and exuded from the openings in the device.
a thousand dollars plus to change out a GFCI? it'd be interesting to see
what he actually did for that money. besides carry it away in a sack.
randy
randy
Burning pvc releases chlorine gas he was just being osha compliant.
I do a lot of testing, site surveys and am asked many times to try to figure out what caused electrical explosions and or fires. What I have done is as Bob said HIRE A PROFESSIONAL. Besides the knowledge they bring to the table they are COURT experts and this alone makes them worth their weight in wirenuts (maybe more).
Sure if you are a trained fire investigator. By the evidence. Why are you thinking about knocking someone off??
The determination of which came first, the fire or the short, is something that is very very difficult to do and it cannot be done without some very expensive forensic testing of the ends of the conductors involved. Yes the evidence can point to the electrical short as the cause of the fire and in the absence of suspected arson that evidence would often be correct, but that is not proof that will hold up in court.
090111-1739 EST
The GFCI picture likely implies a failure within the GFCI. Two major possibilities. MOV failure, or trip coil remained energized.
If the GFCI is opened it should be possible to see which one or both of these devices failed if that was the cause of the smoke. The MOV could simply have been a defective unit, or a sustained overvoltage could cause it to fail. A trip coil failure most likely occurs if the SCR remains on. Again a component failure might cause this, or an adequate overvoltage.
See ELA's photobucket movie at
http://s268.photobucket.com/albums/jj22/transorb/?action=view&current=CoilMishap1.flv
and thread
http://forums.mikeholt.com/showthread.php?t=104129&highlight=GFCI+coil+failure
