Charging Batteries
dicklaxt
When charging batteries in pairs(normal application of charger), can you charge a battery if it is paired up with a second battery that is already charged?
DICK
dicklaxt
In a search I can find answers that would indicate yes,damage will occur and the solution would be a smart charger.
I kinda of thought that(overcharge damage) as I said but if you have a fully charged battery in series with a fully discharged battery wouldn't the smart charger be sensing the current across the series connection and shut down the charger ,this would protect the hot battery but the not fully charged battery would still not be at full charge and be removed from the charging cycle prematurely.
dick
K8MHZ
It depends on the charger.
Some have a charge circuit for each slot so it doesn't matter if you mix and match new and old. Others, particularly older units, have just parallel a single charge unit so for the best performance the batteries need to be pretty close in capacity.
When I first started shooting digital cameras, we marked all the batteries and operated them in pairs and charged them in pairs. I haven't had to do that in years, though.
dicklaxt
I understand,,,,,,,,,,,having a mismatch on voltage readings with 2 batteries in series would confuse the charger into thinking it was two batteries of equal voltages and over charge one and undercharge the other I THINK.
dick
wptski
This happens more you'd think with a battery pack like a DeWalt, etc. where some cells are going bad while others aren't.
SegDog
batteries in pairs
batteries in pairs
Of course, batteries in series need to be taken seriously.
Powerchairs (wheelchairs) generally have two 12 volt batteries in series, and they are charged together. I've changed-out one at a time on occasion, but ordinarily they live and die as a set...
Dog
LarryFine
Batteries are cells in series.
