Jackbenimble7
- CA
Hello all. I am working on a microgrid project where we have the following scenario. There is solar, battery storage, and a fossil-fuel generator installed on the load side of the existing switchgear. We are using a microgrid controller to island the system when the utility goes down. When the utility goes down, the battery picks up the load of the building and provides power until it discharges to a certain level. Once it hits a certain level of discharge, the battery will shut down, and the microgrid controller will send a signal to the generator to kick on and start running. The generator will run until the utility service comes back online.
Two questions.
1. When the battery is providing backup power, can the installed solar also charge the battery? I know that with the Tesla Powerwall, this is possible through the use of their Gateway, but for commercial sized solar/storage without a dedicated connection between the two, I'm not sure.
2. When the generator is running, can solar provide backup power to the building loads? I lean towards no on this, that the solar inverter will not be able to synch with the generator and the output of the solar array may damage the inverter.
Any insight would be much appreciated.
Two questions.
