I just finished hooking up a 480 volt aircompressor and before i turned on any power i used my ohm meter to check for any possible ground faults. I tested from all lines to each other and then all lines to ground, no faults. until i turned on the power. bang smoke and a tripped circuit breaker. :shock: whats the best way to check for ground faults before power, that is correct and doesn't provide a 4th of july show for the plant manager who was standing nearby at the time.
ps i checked both the line and load side of both the safety switch and the motor starter. the short occured when purple wire was nicked by MC connector, and yes an anti short bushing was used, however thats supposed to protect the wire from the cable assemblie.
any info would be great
thanks DR will
thanks DR will
