I went to a job to see why the light over there sink and the light over the toilet and outlet and fart fan wasn't working.house is about 30 years old.So i'm thinking gfci.I open the panel in the garage check the connections,check the voltage,checked the breakers for voltage,turned all the breakers off and on.there was one 20amp gfci breaker,and two gfci outlets outside,all where fine.The gfci breaker was protecting the one gfci outlet outside but nothing else.So i opened up the gfci outlets to see if anything was loose and to see if they were protecting anything else they weren't,just line in.Checked switches and the outlet no power in the boxes.So i connected my "Progressive Electronics Tracer 2 model # 77hp" red to the hot on the outlet and black to the ground.Took my "200ep inductive amplifier" waved it over the switches that were dead got a loud sound,so i wave it around any outlet or switch that was live got no sound.I checked everywhere even in the attic nothing,but i did find big rat traps.I waved it over the sheetrock around outlets and switches nothing.I tried to find a hidden gfci somewhere nothing.I opened up outlets & switches that were live and near the problem nothing.Needless to say i didn't find the problem after 2-1/2hrs the customer said no more.Is this tool i'm using suck?What do you recommend i could have done differently.Thanks for your help.
