Can anyone help me with this, I live in N.C. seems that most of the electricians in the area
I am from ,are locating the Chime transformer behind the chime in a 2- gang plastic box
with no divider. Is there a location in the NEC that states you can install a chime transformer behind a chime rendering inaccessible as well as having high and low voltage conductors occupying the same enclosure. not to mention that on some of the applications I have seen the transformer has no ground except if you attach it to a metal enclosure. Anyway I got grief from a builder who wants to know why I installed it in the garage mounted on a metal plate mounted to a gem box, he says that's not how my last electrician used to do it. And the local inspectors have no problem with it
