I plan on wiring in a stainless steel draft inducer on a chimney top. The motor housing is approx 18" tall and approx 18" diameter. The chimney is approx 20' above grade. The motor is 120 volt and draws less than an amp. I am wondering if it is necessary (I believe yes) to bond a GEC to the unit housing and down to a ground rod and also bond it to the electrical service GEC on the opposite side of the house. The instructions does not mention anything about bonding the housing to a GEC and only an EGC is needed to ground the housing. My concern is the possibility of a lighting strike to the unit and traveling through the EGC. I never installed anything like this and just seeking a second opinion. Thanks.
