hockeyoligist2
- close to greenville sc
I'm not sure if this is the right place to post this and I hope I can explain properly!
Last week we had a very large chlorine leak, killed grass, a tree, bushes outside the building. There are two 460v exhaust fans in the room. One of them blew a fuse, a few days later. I checked everything and the only thing I found was a slight ground on the motor (10 M ohms) I put in a new fuse. The other two went south when I turned it back on. The motor had signs of heat damage, the label was peeling off and burned looking (no meggar without going back to the shop). I had a spare so I replaced it. I checked everything again before hooking up the wires and I was getting 10 M ohms on the wires to ground, which I wouldn't think would blow a fuse. I hooked everything up turned it on, blew another fuse.
I disconnected the wires at the starter and the motor. I got 10 M ohms again. I turned off the other fan to compare since they are both in the same conduit and there was nothing to ground. Then while it was still off I rechecked the other fan and there was nothing to ground. I can turn the other fan back on and I get a ground, but very a low 10 M ohms.
This is getting long, I know. So, I will get to my question. Since the pipe is buried in cement I'm sure it is full of water by now, it has probably been there 40 + years. Would the chlorine increase the conductivity between the deteriorating wire insulation? Maybe going phase to phase? This one has me baffled, and I'm normally not baffled easily on troubleshooting.
