paulgarett
- San Rafael, CA
Should the largest ampacity circuit breakers (such as range, hot tub, dryer) be installed closest to the feeder lugs and the smallest ampacity circuit breakers (lighting, computer) be installed furthest from the feeder lugs? If high ampacity circuit breakers are installed further away from the feeder lugs, will this cause the lower ampacity circuit breakers, which are installed closest to the feeder lugs, effect the load or dim the lights?
It seems to be common sense to install the largest ampacity circuit breakers closest to the feeder lugs. Are there any specific requirements or codes that specify where the circuit breakers shall be installed in a panel, besides load balancing between phases?
