Brien Bradley
Is there a number/percentage used to size feeder breaker that feeds various 1200A panel breakers (one 3000A bkr. feeding seven 1200A bkrs.). I looked in the code book but have been unable to find any info.
brian john said:Or is he asking the ratio of the current rating of the upstream circuit breaker in relation to downstream breakers to coordinate their time current characteristics to minimize (so called) nusiance trips?
georgestolz said:If there is a set of plans for the original installation handy, it might make determining the calculated load at a glance a bit easier.
Depending on what your role is with the installation, it may be a good idea to do your own load calculation, if you suspect that the feeder is overloaded.
It would be a good idea to keep the conversation public (on this thread), as there's a lot of people here with more experience on such a large installation than me.
Can you provide more details as to what led you here?![]()
Brien Bradley said:Is there a number/percentage used to size feeder breaker that feeds various 1200A panel breakers (one 3000A bkr. feeding seven 1200A bkrs.). I looked in the code book but have been unable to find any info.
Yes, Brien, it is - I think you misunderstood what I said. By private messaging me about the subject, then our replies are only seen by you and me.Brien Bradley said:I thought this was a public forum.
