mstrlucky74
- NJ
Is the "rating" of a breaker the frame or trip? If you have 225AF/125AT what "size/amp" breaker is it? I'd refer to it's trip as the "size".
I think that means it is physically the same size as a 225 amp breaker but is a 125 amp trip breaker.Is the "rating" of a breaker the frame or trip? If you have 225AF/125AT what "size/amp" breaker is it? I'd refer to it's trip as the "size".
Frame sizes typically are 125 and less, 150-225, 250-400, 450-600...
Just to add to what the others said, it also matters a little what TYPE of breaker tyou have. An "MCP" / "Magnetic-Only" / "Instantaneous -Trip" breaker as used in a motor starter is typically NOT shown with a frame size and trip rating because that could get confusing. So they are typically shown with the CONTINUOUS rating of the breaker, and the magnetic Trips will be up to 10X that value. So for example you may see an MCP shown on a one-line diagram as "7A MCP", which means the continuous ampere rating of that breaker is 7A, and the magnetic trips will be adjustable from 300-1000%, so 21 to 70A.Is the "rating" of a breaker the frame or trip? If you have 225AF/125AT what "size/amp" breaker is it? I'd refer to it's trip as the "size".
Instant is typically 10 to 12X, every mfr is different.that is the way I read it
225 Amp Frame
125 Amp Trip (I assume thermal), instant ~12 times that
...the spec writer wanted to use a larger frame for some reason.
Thanks guys..very helpful.
Yes, good points. Technology has come a long ways today. The manufactures have learned how to dr design the smsller breaker frames that can kick butt when it comes to kaic but it is hard to pack the options that electronic trip units in the smaller frames that you can get with the larger frames. But I know that they must be working on it.One common reason for wanting to use a larger frame size is coordination.
Several of the protective functions of breakers are dependent on the stuff inside of the breaker, like a current sensor or a physical bi-metal. The larger guts mean more fault or inrush current can be tolerated.
For example a 125A trip unit in a 150A frame breaker might have a maximum instantaneous setting of 1500A (about 12X) but a 250A frame device might go up to 2500A (20X)
They can pack a lot of electronics in a small space if they want to, look at how the computer processors keep shrinking but data handling capacity keeps going up.Yes, good points. Technology has come a long ways today. The manufactures have learned how to dr design the smsller breaker frames that can kick butt when it comes to kaic but it is hard to pack the options that electronic trip units in the smaller frames that you can get with the larger frames. But I know that they must be working on it.
