Circuit breaker panel box cover
Fmkehoe
Cornwall ny USA
Inspector
Somewhere, somehow in the construction work the cover for the circuit breaker panel got thrown out. Can one be made out of plexiglass? Does it have to be sheet-metal? And does it have to have a closing door on it? It’s in an unfinished ratty basement. Thanx.
I would say you need to do one of the following:
1.) Contact the panel mfg and see if you can get a new cover
2.) Find a used one from a "bone yard" someone might have
3.) Get a metal shop to make you one
4.) Buy a new panel, take the cover and use it, keep the "guts" and cabinet for future
metallic cover shouldn't be a problem, non metallic I think would need to be listed.
Metallic type 1 enclosure are not required to be listed, so presumably you could make your own.
